I just got my WinTV PVR, and I haven't had a chance to play with it a lot. But, when I set it up, and it did a channel scan, it didn't find any of my cable channels. Is there something special that I have to do? Or, should it autodetect them? Any help would be appreciated.
What type of antenna did you select from the list, if you search the wrong antenna (frequency range) you wont find any channels.
Make sure your PVR is hooked up to raw cable, no cable box or VCD before the PVR.If you have a cable box then running into the PVR then all you will get is either channel 3 or 4 whatever the box is set to.
I have a PVR, but just use the SVHS and audio imputs only, let me tell you forget the VCD setting, it SUCKS, use the patch that hampuagge has at their web site for SVCD and DV settings, SVCD MPEG2 is fantastic.
Their patch is only for WIN98SE, WIN98ME, NT, WIN2000.
If you have WIN98 1st edition or like me WIN98 Gold it will not work.
If you can't get the patches I have special regedit patches I got from the german hampuagge site that let you change any settings you want manually. email me at
thxkid@hotmail.com if you need the patches, only about 200k size.
wintv pvr usb2 in linux
By diablo in forum Capturing and VCRReplies: 0Last Post: 10th Sep 2011, 09:43 -
Hauppauge WinTV-PVR 250
By thatsgame1 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jun 2011, 07:54 -
Hauppauge WinTV PVR 250
By kenmo in forum ComputerReplies: 10Last Post: 28th Apr 2009, 14:21 -
WinTV-PVR-150 MCE
By prabha in forum Capturing and VCRReplies: 3Last Post: 13th Aug 2008, 11:39 -
Considering Hauppauge WinTV PVR 350...
By chewie8008 in forum Capturing and VCRReplies: 9Last Post: 2nd Oct 2007, 18:20
