im trying to save as .avi my movie but when i try to save it gives me this error : acm failed to suggest audio...
i do: video > direct stream copy , audio > full processing mode , audio converstion 44100 high quality.
and when i try to save as .avi i get the error.
its (unknow tag 2000)
what i do?
(i installed ac3 codec from nimo)
AC3 audio is unrelated to ACM. What is your source audio (i.e. Stereo, Mono, Bit's, sample frequency). What Compression settings are you attempting to use? (AUDIO | COMPRESSION )
Impossible to see the future is. The Dark Side clouds everything... -
Your extracting the AC3 from virtual dub using Direct Stream Copy, yes?
Use AC3FIX. It is a known issue, that virtual dub introduces frame errors in the AC3 stream when extracing AC3 audio. AC3Fix will correct these for you, and fix your sync problem.
You can find a copy here:
http://download.divx.net.nz/software/audio/ac3_fix03.zip
It's pretty simple for fomatting:
AC3FIX.EXE {sourcefile} {destination file}
example:
ac3fix "c:\temp\inaudio.ac3" "c:\temp\outaudio.ac3"
Note: use quotes around your avifilepath if your path contains any spaces, or the program won't understand the filename.Impossible to see the future is. The Dark Side clouds everything... -
Your saving it as WAV, and converting it to 44.1 Khz?
Your DVD player supports AC3, but not for VCD, CVD, or SVCD. Are you trying to convert this to one of those, or are you converting to DVD?
Assuming your going to VCD, CVD, or SVCD (since your resampling to 44.1 Khz), try selecting FILE | SAVE AS WAV with FULL PROCESSING selected under the AUDIO menu, WITHOUT converting to 44.1Khz. Do you still get the error?
Suggested Method:
Set VirtualDub to AUDIO | Direct Stream Copy
FILE | SAVE AS WAVE
Name your file EXTRACT.AC3
Run AC3Fix to repair the bad frames.
Use BeSweetGUI with SSRC to convert to 44.1 Khz.
VirtualDub just doesn't handle AC3 audio well. Extract it, and work on it with tools better equiped to handle it.Impossible to see the future is. The Dark Side clouds everything...
mp3 in acm wrapper?
By DarrellS in forum AudioReplies: 5Last Post: 11th Oct 2010, 21:30 -
AC3 ACM Will Not Install with Vista 64
By Mitchum22 in forum AudioReplies: 4Last Post: 19th Aug 2009, 09:15 -
Can't install Lame ACM
By suerpflysocal in forum Newbie / General discussionsReplies: 1Last Post: 7th Feb 2008, 08:16 -
Problem with AC3-ACM ???
By kehn in forum AudioReplies: 2Last Post: 26th Jul 2007, 23:05 -
AC-3 ACM Codec na RMVB = PROBLEM
By krain_l in forum Authoring (DVD)Replies: 1Last Post: 16th Jun 2007, 17:48
