I was just curious what everyone used to create menus for their VCDs.
I'm new to this whole thing and I've grown quite an attachment to VCDEasy. I've been able to use scene menus I created in Photoshop 6.0 in VCDEasy and create MPG stills from them. The quality is quite good since I'm using a resolution of 800x600 without cropping for the design of the menu itself. I've also got it so that I now have a template I use to create the menus too.
The nice thing about it all is that there is no limit to what you can do with MPG stills since they are all designed in Photoshop. I guess its left up to imagination of the author.
I'd love to know too.
I use VCDEasy & Ulead movie factory. VCDEasy is better by far! -
ulead dvd workshop can do a great job with dvd or vcd menus including background music. You can lay out the menu exactly the way you want it with your own art if you are creative.
I use VCDImager to make menus... I encode the stills with either VCDEasy / MJPEGTools or CDMotion.
Regards.Michael Tam
w: Morsels of Evidence -
Ulead Video Studio 6 (the VCD/SVCD/DVD plugin), but the DVDWS app has more options (and is triple the price).
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Encore DVD Menu Authoring
By montgal in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th Apr 2012, 23:24 -
Authoring DVD without a menu?
By Humptydank in forum Authoring (DVD)Replies: 6Last Post: 29th Mar 2010, 16:55 -
TMPGEnc Authoring Works 4 - Menu help
By NotSoEasy in forum Authoring (DVD)Replies: 9Last Post: 1st Mar 2010, 02:24 -
ever had this menu authoring problem before?
By uglijimus in forum Authoring (DVD)Replies: 5Last Post: 22nd Oct 2009, 14:06 -
dvd authoring with hidden menu
By VeryNewbie in forum Authoring (DVD)Replies: 1Last Post: 21st Jun 2007, 03:21
