I have been trying to use the TMPGEnc-2.59 to convert .avi to mpeg. After I choose source, etc...it always give me the same message "cannot load P3P .dll package or cannot load P4P .dll package". I have went to the website, and it says maybe it was the program I used to unzip. I have used WinZip 8.0 and PowerArchiver (both retail versions and updated) and always get the same results. I have sent email to company, however who knows? Pentium 4, 120HD, 512mb ram, Win2k, Sony DVD burner DRU-500A (external)--(EasyCD Creator 5 and RecordNow Max installed) Anyone know what I am doing wrong?Debbie
(If this question has been asked before, forgive me, I didn't find it.)
Go to the folder where the TMPGEnc.exe command is located. You should see both the P3P .dll and P4P .dll packages. Chances are they are missing from the folder.
Hi--I found the folder, the P3P and P4P are there, but I see no way to install them--in fact, there is no set up at all in this download! I have downloaded it three times, no set-up. I double-click on the exe to start the program, but that doesn't work on the P3p, etc. Debbie
If the dll files are in the folder they should load. If your TMPGenc is "freeware" it's possible that there is something wrong with the program or the dll files. Possibly you could get it from another "freeware" site.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
TMPGEnc to License x264 Encoder for TMPGEnc 4.0 XPress
By poisondeathray in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2011, 15:07 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
Debbie
