Hi all,
I've been using NVDVD 2.20 for playing DVD's recently, and all was well until I installed InterVideo WinTVR - now NVDVD gives me an error when I try to use the DVD-player part of it, saying it can't open the DirectShow graph or similar. I noticed that .m2v files in Windows Media Player were using the InterVideo video & audio codecs...so I uninstalled InterVideo, uninstalled and re-installed NVDVD, but still got the same error...then I noticed that WMP was still using the InterVideo codecs...
...so how do I uninstall these codecs, as the InterVideo uninstall clearly isn't doing so, so that I can re-install NVDVD and it's codecs?
Thanks.
Try DXMAN at www.analogx.com
That's what I use.
What I am really looking is how to tell windows what codec to use which is better.
I have seen in may computer elencard mainconcept Cyberlink ligos codecs
The best way it would be to learn how to control them.
But for now use DXMAN -
Excellent - I've just downloaded this and I can see both the InterVideo & nVidia codecs
I think I'll get a reg dump before I uninstall them, so I can run a comparison when NVDVD is installed, so I can switch between the two set sof codecs by running a small reg file...
Thanks for the help
Cannot uninstall Nero 9
By jyeh74 in forum Newbie / General discussionsReplies: 2Last Post: 25th Dec 2009, 08:31 -
uninstall every trace of any video codec
By greendesert in forum Software PlayingReplies: 8Last Post: 20th May 2008, 11:27 -
Can't uninstall codecs
By boonebaker in forum Newbie / General discussionsReplies: 8Last Post: 7th Mar 2008, 16:09 -
How do you uninstall WMP 10?
By rayden54 in forum Software PlayingReplies: 5Last Post: 8th Jan 2008, 15:59 -
How can I uninstall Huffyuv?
By Xoanon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 15th Jun 2007, 10:55
