I'm getting an error message when I try to import an AC3 file into DVDMaestro. I created the file in DVD2AVI. The error message reads: "Cannot locate a frame SYNC word at an expected byte offset. Data might be corrupted. (0xc1070042)". This is my first time using Maestro. Any ideas where I might have screwed up would be greatly appreciated. Thanks!
Edit: I tried muxing my m2v and ac3 files w/ TMPGEnc. The resulting mpg had no sound.
Hi,
I had the same problem. How do you demuxed the AC3 ? With DVD2AVI. In this case, demux direct with DVDDecryptor. This AC3-Stream can be imported in Maestro.
With only one DVD until now I had this problem. -
Thanks Laddi!
Last night I determined that the problem was with DVD2AVI. If I set Audio to decode everything is fine. I can play the resulting wav file. When I set Audio to demux, the resulting ac3 file is blank. In this case I get 93 min. of silence. I'll have to try another movie to see if it is a problem with this particular movie (Shrek). There was also a problem with the chapters on this movie - couldn't get Maestro to read them. I didn't know DVD Decrypter can demux. I'll try that also.
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
Nero Error Msg - 'Prepare Session Failed'
By Dieseldog in forum Authoring (DVD)Replies: 0Last Post: 19th Dec 2011, 06:38 -
Question about Windows error msg and high cpu when right clicking on avi
By jimdagys in forum ComputerReplies: 3Last Post: 4th May 2008, 17:01 -
error msg when try to record on drw-500
By harryb in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2007, 23:57 -
TMPGenc just closes - no error msg - no rhyme or reason! Help please.
By brightsun23 in forum Video ConversionReplies: 3Last Post: 15th Jun 2007, 11:42
