Hi guys,
Sometimes when I play back VCD or SVCD on my DVD player I get mosaicing & freezing up during play back.
I think this is due to either the burning or the CD-R's i'm using.
Could anyone recommend a brand of CD-R? Also whats the best burning speed when burning a CUE/BIN image?
Thanks in advance.
Results 1 to 12 of 12
You'll have to experiment - Your particular make and model of DVD may like one type of CD's best - your writer hopefully agrees!
As for speed, I use to stick to "never above half burner max write speed" Not that I can understand why (it's a digital world, after all, right?), but this works best for me...
/Mats -
Like mats says, it all depends on your burner and the media you use.
I can burn VCD's at 52 speed on my 52x24x52 Lite-on using 48 speed intenso media. No problems so far. -
Thanks for replying guys,
I've been using intenso 48x discs and been burning SVCD.
My writer is a BTC, 2410 i think.
Would a SVCD be more sensitive to burning speeds?
My player is a philips DVD723. -
Originally Posted by thesicilian
I normally burn @ 4x or 8x.
Are BTC burning any good?
I am better off investing in a better burner? -
I dont know about BTC burners, but you shouldn't be having problems burning at 4x. If you do get a new burner, consider a lite-on. Have you tried your SVCD in any other players to see if you have the same problems, and its not just your DVD player that is having trouble reading the discs.
Whats the best burning software?
I've been using TMPG for encoding
VCDEasy for chapters then to cue/bin image
Nero for burning image.
Is their a setting in nero that i might be missing? -
I use Nero to author and burn my VCD's with no problems, although some people do have problems with it. If you are authoring with VCDEasy, why not try burning with it as well. Can't hurt to give it a try.
I like nero but am I right in saying that u can only have one track on the menu, whereas vcdeasy can create a number of chapters.
You can have multiple tracks in nero, which can be accessed by a menu. You just drag as many mpeg files across as you want on your VCD. You cant have chapter entry points within a track with nero though.
I've purchased some TDK discs today.
Gonna try tonight @ the same speeds, then faster. I will let u know how i get on.
Is there any other easy to use software to create menus & chapter enrty points?
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
