Hi Im new to this forum and am looking for some advice...when im converting some films to vcd using TMPGEnc the finished file has no sound, I have tried using virtual dub to extract the audio but am getting the same results...dont know it its something im doing wrong or if the files just cannot be converted....divX to vcd
Any help would be greatly appreciated![]()
Try and describe the process in more detail. How are you getting the audio from virtualDub? Are you trying to convert a NTSC divx into a PAL VCD? Is it just the one file or all of them?
GGS.Eat! Drink! Be merry! Tomorrow we snuff it! - (Sid James, from 'Hancock's Half Hour') -
There's 3 different films Im having this problem with...102 dalmations divX, Cats and Dogs divX and spiderman.....They are all downloaded using verified links from fast track central.
Its PAL I have set for, dont know what the actual films are,,,,,is there any way I can find out? I am relatively new to the vcd burning but for the most part I have had success. -
WooHoo read some more of the posts in the newbie section, and tried the enviromental/vfpai plugin make direct show higher priority solution and it cured the sound problems I was having!
Excellent. Glad to hear you got it solved.
Sound out of Sync in conversion
By opala in forum Video ConversionReplies: 2Last Post: 17th Apr 2009, 20:15 -
conversion loses sound half-way through
By santino_avi in forum Video ConversionReplies: 5Last Post: 21st Oct 2008, 12:35 -
HD WMV w/5.1 Sound Conversion to iPod Format Problem -- Help Please!
By VixenofVenus in forum Video ConversionReplies: 10Last Post: 2nd Oct 2008, 13:59 -
Analog to digital conversion-no sound
By schiass in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2007, 13:21 -
there's no sound with my mpeg-1 conversion
By darealest1 in forum MacReplies: 1Last Post: 13th Jul 2007, 09:12
