  1. loveo... i hope that someone can help me...
    i have successfully used smartripper to rip the dvd to my hard disk...
    i have also successfully gone through the steps using dvd2avi...
    i then wait ages for TMPGEnc to create the mpeg... when it's finally done i play the mpeg before i burn it... the sound is fine, but the video is grainy and choppy... i used the default settings for TMPGEnc...
    am i doing something wrong? does anyone have any suggestions...
    if it helps at all, the movie was dancer in the dark...
    i would really appreciate it if anyone could help me...
    thanks in advance...
  2. Need a few more details:
    1) did you ever burn VCD (or SVCD) and play them successfully before
    2) did you rip your movie to VCD or SVCD, etc.. ? What are the TMPGEnc settings
    The procedure seems correct and should work.
  3. Guest
    mmm, you used the default settings from this site or from tmpeg ?
    tmpeg' settings are really crappy ! Also there is a difference in settings between VCD en SVCD, what are you exactly making ?
    GrEeTZzz
  4. Try loading the template for NTSC (or PAL) VCD from the template directory. TMPGEnc will take a long time on an older or slower machine.
    -TMPGEnc encoding times (Personal records)-
    VOB/PCM WAV to VCD, 74 minutes of MPEG generate,
    AMD K-6/2 500Mhz : 9-12 hours
    (Old machine)
    AMD Athalon Thunderbird 800Mhz : 3.5 - 4.25 hours
    (Yup, new machine! Thank you Lord!)
    [Both have the SAME hard drives and 256 megs RAM]
    HTH
    <font size=-1>[ This Message was edited by: VideoGuy on 2001-08-28 21:55:29 ]</font>
    <font size=-1>[ This Message was edited by: VideoGuy on 2001-08-28 21:56:19 ]</font>
