  1. hi
    I downloaded a file in avi format. The file is 106 minutes long, but when i try to convert it in Tmpgenc Wizard it says that the file is 315 minutes long and that the file will be about 6 gigs with the settings i choose.
    What can I do?
    Please help...
  2. This is probrably because it has a variable bitrate audio stream, which TMPGEnc cannot handle. You need to save the audio as an uncompressed wav file and then use that as your audio source in TMPGEnc.
    Here is the guide for how to do this.
    http://www.vcdhelp.com/virtualdubaudio.htm
  3. Thanks alot Craig.
    Will try that when I get home from work
  4. If it works, perhaps you can change your name to happy_luke
