I've been checking Sefy's guide but it does not say how to get subtitles even though on the dvdrip section it says with or without subtitles,so how do I get subtitles with Smartripper?any reply would be greatly appreaciated thanks.
well the easiest way to do it is to get ChapterXtractor. not sure if you can get the subtitles with smart ripper..........
Okay I checked the Ifo file on ChapterXTractor and I check one dvd and it said this SubPicture:
0. English (0xBD 0x20)
1. English (0xBD 0x21)
2. Espanol (0xBD 0x22)
3. Francais (0xBD 0x23)
4. English (0xBD 0x24)
How am I suppose to get it now? -
to add subs to your rip:
http://www.vcdhelp.com/dvdtovcdflask.htm
http://www.doom9.org/index.html?/subtitle_guide.htm -
There are plenty of ways to get Subtitles in your Movies, Smart Ripper is just
a Ripper, it copies the movie into your HDD, the Subtitles depend on other
programs.
1. DVDx - Easiest way to select and encode with Subtitles
2. FlaskMPEG - Second Easiest, but requires Encoding Components!
3. DVD2AVI,VirtualDub,TMPGEnc - Major Combo, but Excellent Quality!Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 08:22 -
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 18:44 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 17:30 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 20:21 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 09:23
