i open tmpgenc and loaded the .d2v and .wav
but when i encode it says the following...
The error occured when the ACM was initialized....
what does that mean?
Results 1 to 9 of 9
i have this same problem now !! i really dont know how to fix it i allmost broke my pc !!
some 1 help , please .
ACM is a standard audio codec, which is commonly used for the audio in an WAV and AVI files. It is installed by default if I remember correctly. I hesitate to suggest what could be causing the error.
What are the specifications of your WAV file (i.e frequency, bits)?Impossible to see the future is. The Dark Side clouds everything... -
hello !
well its happing now for all my movies , even those that i did 3 days ago ' and they work prefect then !
what i need to do i have all the codec please some 1 ! -
AC3 and ACM are unrelated. Do your AVI's play back without issue? This only happens when you try to encode with TMPGenc? What audio compression options are you using?
ok !
:P
after 3 days that i allmost shot myself with m -16 !
i know the answer to this problem
for xp windows , i really dont know how the other versions run , but its Should be the same way )
1)go to your control panel
2)choose sounds and audio devices
3)inside the sounds and audio devices choose hardware
3)there go inside audio codecs and there remove , but only the codecs that not windows codecs !!!!! (divx , xvid and so ... )
4) go to video codecs and remove all the divx and xvid video codecs !
6) unistall dvd2svcd and tmpegnc
7)after all those steps , restart (reboot ) the pc !
8)install all the divx and xvid codecs and mpeg 3 layer coedec ! (i dont like nemo pack but you can also install them ) !
9)install dvd2svcd and tmpeg !
10) say thank (you welcome ) hehehehe ! -
Did you inadvertantly remove your ACM codec at some point, or install some codec pak that caused a conflict? It would be more helpful to someone further down the road, if you told them what to avoid in the first place, rather than just a fix for the problem.
mp3 in acm wrapper?
By DarrellS in forum AudioReplies: 5Last Post: 11th Oct 2010, 21:30 -
Vegas + LAME ACM = just a myth..?
By Gew in forum EditingReplies: 3Last Post: 24th Jul 2008, 02:48 -
Can't install Lame ACM
By suerpflysocal in forum Newbie / General discussionsReplies: 1Last Post: 7th Feb 2008, 08:16 -
Problem with AC3-ACM ???
By kehn in forum AudioReplies: 2Last Post: 26th Jul 2007, 23:05 -
AC-3 ACM Codec na RMVB = PROBLEM
By krain_l in forum Authoring (DVD)Replies: 1Last Post: 16th Jun 2007, 17:48
