loveo all.
this forum is the best.
Thanks all for all the help you guys give me.
now to my question.
I´m Newbie on mini DVD.
How do I do if I would like to convert a *.wav file to *.ac3 file.
and how do i split up my *.m2v in two pieces.
appreciate for help.
I'm not a miniDVD expert re: the question you have. I think if you have PCM WAV file, you'll only end up with a 2.0 ac3 file, which is the equivalent of compressed stereo. You'd probably do as well or better to make your WAV file an MPEG-1 Layer 2 file for use on your miniDVD ... or, perhaps Sonic Foundry SoftEncode makes ac3 files. I've never tried it for anything.
Yes use Soft Encode to make your Ac3 file...if you your ripping from a DVD, then is no need to make a wave file first....just input the ac3 straight into soft encode..and us the app to lower the bitrate on the ac3 file....so you can keep the 5.1 surround..if not, then yes use the wave file...from whatever source you orginally got it from.. email me if you need further help
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 15:54 -
VirtualdubMod - no ac3 sound in Windows 7 64?
By burcs in forum AudioReplies: 0Last Post: 8th Feb 2010, 18:09 -
no sound on dr. divx ac3
By jwdove in forum DVD RippingReplies: 1Last Post: 25th Jun 2008, 05:07 -
No sound when playing AC3 files...
By GangstaRap in forum AudioReplies: 1Last Post: 10th Feb 2008, 00:21 -
AVI with AC3 - No Sound
By Degradation in forum AudioReplies: 0Last Post: 19th Dec 2007, 17:28
