I am burning VCD onto CDRWs. Once I play the file in my home DVD I usually record to VHS tape ok. Now how to then delete the file(s) from my CDRW then prepare it for another file(s)? I am using EasyCD Premium..So basically I want to re-use the same CD and keep copying onto it freeing up the CD each time after I have copied to VHS tape. Any suggestion/help is greatly appreciated. Thanks.
I'm not familiar with the current versions of Easy CD Creator, but most programs have an option somewhere like "blank cd" or "erase cd". I do know that it has pretty good help, doing a search for "blank" or "erase" might tell you what you need to know.
One thing to be aware of is that CD-RWs eventually wear out. After a while you may start to get colored blocks or other noise in your VCD which aren't in the original, that means it's time to use a new disc.
DVD+RWs no longer play
By Iconoclast in forum MediaReplies: 31Last Post: 26th Mar 2012, 20:59 -
Trying to use DVD+RWs with Imgburn and Megastor 16xDVD9
By w6rlf in forum Newbie / General discussionsReplies: 2Last Post: 4th Feb 2012, 23:02 -
Erased -RWs no longer recognized - HELP!
By will7370 in forum Newbie / General discussionsReplies: 6Last Post: 5th May 2009, 18:08 -
DVD+RWs going bad
By lmemsm in forum MediaReplies: 18Last Post: 12th Jun 2007, 13:40 -
Problem formatting DVD+RWs
By Sephiroth666 in forum MediaReplies: 12Last Post: 12th May 2007, 12:51
