  1. I have been around playing with VCD/SVCD for a while now but I cant seem to figure this problem out by trial and error so im hoping someone here can help me.
    Im looking to make my own little Animation to add in front of my movies.
    I can make the Animation in either .gif or with windows movie maker.
    My problem comes into play when I try to add this into the movie.
    I can only seem to add Still pictures in by using VCDeasy.
    Can anyone help me with this problem.
    I hate to ask because I try to figure things out but im sorta at my wits end.
    Thanks for any help you can give.
    Edit: I forgot to say why. When I rip my movies I cut out all the words and credits from the rip. Im looking to add a animated movie to the front that would scroll the name of the movie around and stuff.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    convert your animation to a avi and encode the avi to mpeg ...
    swish is excellent for this and can produce amaizing results .. and its cheap .. and i use it also .. http://www.swishzone.com/
  3. Windows Movie Maker shoiuld work fine - any way to get it to an avi then your can encode to MPEG with your favorite encoder like TMPGenc.
    In VCDeasy add the animation MPEG as the first motion mpeg. then add any content after that (menu or movie).
    Panasonic DMR-ES45VS, keep those discs a burnin'
  4. Thanks for the help. I will check into that. If thats all there is to it im going to smack myself.
