Anyone found a Macrovision hack that works for this player?
Must be loads of these players out there, most stores are out of stock again.
Player Info:
Just got a Pacific 1002 for Asda in Bury(13/12/02) for £69.83(3yr Guarantee) looks the part - plays VCDs, sVCDs, MP3s, CD-R(few makes) & CD-RW(Memorex) & DVD-Rs(few makes) with no problem.
Outputs: x1 Scart, x2 Video, Left & Right Stereo Audio, S-Video, optical & coaxial output.
The first one(Warrington) I had was faulty, Asda exchanged it.. & I've noticed a slight difference in the two players: when using the fast Forward, the first one said x1, x2, x4, x8, x16 & x32(DVD)... in the top right corner. This one just has FF 1, 2, 4 & 8(DVD)... in the left corner, & I'm sure the first player didn't have a zoom of x1.5 & this player makes a ping sound when you open the drawer - maybe there are different batches or something, anyone else's different?
This is the only hack that worked on my player:
Ensure Region 2 DVD is in the Player
1. Press "setup"
2. Press "1" for region 1 or press "2" for region 2...press "7" for bypass Region code.
3. Press "PAUSE/STEP"
4. Press "previous"(|<<)
5. Press "next" (>>| )
6. Press "setup"
Only this hack worked on the 1st player I had:
1.on the remote press open/close
2.press clear
3.press 1
4.press 3
5.press 6
6.press 9
7.press region number 1 to 6(0 for region free)
8.press open/close
The 1st 1002 player can display jpeg files & could not play DVD-Rs, this 2cd one can not display jpeg but plays DVD-Rs.
Can someone help me please Pacific dvd
By jackplug in forum DVD & Blu-ray PlayersReplies: 18Last Post: 21st Apr 2010, 12:12 -
Durabrand 1002 DVD Player
By markyl in forum DVD & Blu-ray PlayersReplies: 4Last Post: 6th Dec 2007, 11:56 -
Philips 1002 DVD not working: CD's are
By gunnsr in forum Portable VideoReplies: 1Last Post: 20th Oct 2007, 15:50 -
Pacific DVD-1002 hacks
By mark2004uk2 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 26th Jul 2007, 09:22 -
Pacific Digital U-30297 External DVD+RW
By vaporware in forum DVD & Blu-ray WritersReplies: 1Last Post: 11th May 2007, 11:35
