I have got pretty good 480x480 avi's captured with virtual vcr and am using dvd2svcd with cinemacraft 2.5.
If I am not concerned on space ie 40 vs 60 minutes per cd, and my dvd player can play up to 2400 kb/s. Is there a quality reason to use VBR 2+ passes. OR will CBR at a high bit rate work just as well.
Has anyone found the "drop dead perfect" setting to encode an interlaced 480x480 into high quality svcd's?
Multipass VBR will gain you better scene detection and bitrate allocation. Try using multipass with min, avg, and max all set to 2524, since your not worried about space. You will still gain the benefit of multipass.
Impossible to see the future is. The Dark Side clouds everything...
Sony Hi8 has been defective but want to play the Hi8 tape
By coody in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 22nd May 2009, 22:06 -
Hi8 to DVD
By 21Wiz in forum Newbie / General discussionsReplies: 3Last Post: 2nd Oct 2008, 01:25 -
Hi8 encoding
By devin122 in forum Video ConversionReplies: 17Last Post: 17th Jan 2008, 11:41 -
Hi8 vcr, better playback than a Hi8 camcorder?
By Knightmessenger in forum Capturing and VCRReplies: 8Last Post: 22nd Dec 2007, 01:11 -
Will cheap new Hi8 camcorder output better than old, worn Hi8 camcorder?
By ErikL7 in forum RestorationReplies: 7Last Post: 2nd Sep 2007, 06:26
