I am trying to use Unlead DVD to burn movies to a dvd... but when i try to load the movie it says "...mpg is not DVD MPEG file. Please select a DVD compliant file." I have converted everything already using TMPEG but still it dosent work. Any have an idea why?
What format and settings is your MPEG file ?
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
I converted to an svcd .mpg with TMPG because if i convert to dvd it's breaks it up into 2 files.
Guys i really need help with this one, i have been searching around and havent come up with a reson why it's not working,
Well there is your problem DVD does not support the SVCD resolution. Why couldn't you lower the bitrate for DVD so it would fit on 1 disc ?.Originally Posted by Crash-n-Burn
This link may help you to make a SVCD-DVD. But it may not work on your player.
http://www.vcdhelp.com/svcddvdr.htm
If you still have the original source video, I would reencode to something that is DVD compliant.
The official (legal) resolutions for optical media are:
720 X 576 (480 NTSC). Used by most DVD.
704 X 576 (480 NTSC). Used by some DVD
480 X 576 (480 NTSC). Used by SVCD
352 X 576 (480 NTSC). Used by DVD and China Video Disc (CVD). It is also the "official" SVHS resolution.
352 X 288 (240 NTSC). Used by VCD and DVD. It is also the "official" VHS resolution
capturing dvd compliant mpeg-2 with vdub
By wolfdogg in forum Capturing and VCRReplies: 0Last Post: 10th Jan 2012, 20:06 -
How do I make an MPEG-2 dvd compliant file into a authored dvd?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 13Last Post: 12th Mar 2009, 16:10 -
need to join 2 dvd compliant mpeg files (having identival characteristics)
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 20th Oct 2008, 11:37 -
Video corruption when trying to convert MPEG-2 to DVD-compliant
By DB83 in forum Video ConversionReplies: 2Last Post: 31st Jan 2008, 20:00 -
No audio in dvd compliant mpeg 2 files
By Bertieboo in forum Video ConversionReplies: 6Last Post: 14th Nov 2007, 16:35
