    Dec 2002
    Belgium
    I try to make a slideshow with animations in an .avi file and I'm using Premiere.
    The .avi file that I obtain is wrong. Video is delayed of a few seconds. Some pictures and animations are not shown exactly as it should or are skipped! I think(but I know absolutely nothing in it) that this problem is due to the codec I'm using. I use a MPEG-4 codec, quality max.,resolution 1024*768, 30 frames per second, optimize still images.
    Thank you very much for your help!
    Feb 2002
    Texas, USA
    Make sure that your actual project settings are the same as your export. I had problems with audio sync and a majority of the time the problem was my project settings were off (like 48hz sound instead of 41, etc)
