Hi,
Can anyone help?
Backing up a DVD using DVD2SVCD, everything seems to go ok then importing assets into SPRUCEUP i get an error like inconsistent bitrates on ac3 file.
I have done a couple successfully before this, i did however change back to VCD settings for another disk, can anyone suggest what i have done wrong?
I think i seen Audio Bitrate on DVD2SVCD, it is at 192 just now but i think i have had it set to 224 at one point. cant remember which one worked.
Dont want to wast another 12hrs or so.
Gary
i use spruceup all the time and after backing up over 50 dvds i have had the same problem once.
it all came down to a bad original disc. (few scratches).
have you checked your disc ?
hope it helps.
thingimijig.
Inconsistent Levels result with filter
By cornfluke in forum EditingReplies: 5Last Post: 17th Dec 2010, 07:24 -
Opening .ac3 audio files in Sony Vegas?
By Thunderhead2772 in forum EditingReplies: 1Last Post: 18th Jul 2010, 20:55 -
Problem with MKV to DV - Inconsistent Quality?
By aboutblue in forum MacReplies: 2Last Post: 19th Apr 2009, 13:54 -
Opening Video with MP3 audio in VirtualDub!
By Ace-Of-Spades in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2008, 10:18 -
inconsistent audio sample rate error in FCE...
By ednarophati in forum MacReplies: 1Last Post: 23rd Aug 2007, 13:59
