  1. File size: PAL DV AVI 30" - children into swimming pool
    System settings: Dual Xeon 2.4 with Supermicro P4DCE+, 1024 MB Rambus Samsung PC800
    Standard Bios setting (no overclocking or performance enhancing optimization)
    W2k pro SP2 and XP pro - no sp
    DC precision 10
    Standard matrix for Tmpgenc
    vbr setting min 2000 avg 6000 max 9000
    Program release: Tmpgenc 2.59 Plus and Procoder 1.035
    Both encoders have been set to High priority into task manager
    Source file is on separate disk than target file
    Encoding Times:
    Windows XP PRO - ht enabled
    Tmpgeng hq 2pass vbr 3' 25"
    Procoder hq 2pass vbr 2' 38"
    Procoder mq 2pass vbr 13' 35"
    Windows 2k PRO - no ht
    Tmpgenc hq 2pass vbr 3' 00"
    Procoder hq 2pass vbr 1' 54"
    Procoder mq 2pass vbr 8' 20"
    Windows XP PRO - ht disabled
    Tmpgenc hq 2pass vbr 3' 23"
    Procoder hq 2pass vbr 2' 12"
    Procoder mq 2pass vbr 12' 55"
    Average Q value:
    Tmpgenc hq 7.7
    Procoder hq 4.68
    Procoder mq 4.63
    I remain waiting for your comments
    Cheers
    Paolo
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    IBM says dont use Hyperthreading with dual xeons for most apps - even if hyperthreaded enabled .. unless you are running several (many) apps at once ..
    rather strange - but whatever ..
    i have a dual xeon 2.6 also, ibm intelistation (MSI board, as it one of the few boards approved for dps boards) , and get faster speeds than that for tmpgenc .. do you have a large cache enabled in tmpgenc for vbr 2 pass? i also just ordered a dual ibm xeon 3.0 w/ 533 buss and DDR memory -- be interisting to compare to the dual xeon 2.6 w/ rambus to DDR ..
