I got a copy of Premiere 6.5. But I cannot find any tutorial to use it to conver avi/DV to MPEG2. If I want to convert/copy SVCD/DVD, can I use it or I don't need it?
Thanks.
yes you can use it .. BUT you must call adobe service centre with your serial number and they will send you the nessessary upgrade pack .. free .. it not a download avaiable on-line (unless you know the link, avaiable for registered users only).
it works then very well ..
there are many templates and such included on the installation cd , also very good manual and tutorials come with it ...
the adobe help forum is very active and great place to go with problems and quaestions - there is a dedicated forum just for mpeg encoding with premiere. -
in fact -- there is a huge manual on the installation cd just for the mpeg encoder .. very detailed ...
Covert AVCHD to good quality DVD in premiere, how to?
By Kentho in forum Video ConversionReplies: 14Last Post: 21st May 2012, 10:10 -
Premiere RGB exports produce bad frames - is YV12 a good alternative?
By spicediver10191 in forum Video ConversionReplies: 5Last Post: 21st Feb 2011, 17:02 -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 04:22 -
What are good specs for a high-quality MP4 file? (Will look good on my 40&q
By HarlanPepper in forum Video ConversionReplies: 6Last Post: 11th Feb 2009, 03:18 -
lossless video-codec good for editing in Premiere
By phpmysql348 in forum Video ConversionReplies: 4Last Post: 11th Jun 2008, 21:41
