  1. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    I'm using CladDVDxp, DVD2Avi and TMPGEnc to rip Minority Report and yet can't produce a sound file.
    I've even gone back to CladDVD v1.63 and still the same.
    I've never had a problem prior to this.
    Anyone any ideas?
    Thanks,
    Will
    WinXP
  2. i use dvddecrypter in ifo mode- never had any probs. used the same software as yourself for the rest of the process. make sure that track 1 is ticked in the audio options in dvd2avi..hope this helps
  3. Lost Will Hay's Avatar
    Oct 2002
    Hello, thanks for the post.
    I remember this clealy, 'track 3' was checked.
    I just did Chicken Run and that was track 3 too (and I'm having problems with that too).
    Strange this, I've never had and problems before and never had reason to check the audio settings.
    I have just upgraded to XP though.
    Will
  4. most of the time, the audio you want is in track 1
