I cannot make copies of some svcd's. I'm using Easy Cd Creator 4.02, updated to 4.05. When I use the CD Copier, I get a messege stating, " An error has occurred while reading the CD-Rom drive. Ensure the drive is properly connected and the correct CD is inserted in the drive".
I can burn audio cd's, and have used the CD copier before, and never received this messege.
Also I have never messed with any of the inside wiring, or settings at all.
I used to use Adaptec burning software, but I found with each new version the software got bigger and more buggy. I would recommend using Nero to burn (S)VCD.
As to copying SVCD, many people have success with various software. However, my preferred method is to first copy the mpeg to my HD. Then I use TMPG to multiplex the mpeg, and burn the new mpeg to SVCD.
Although this is only one option, it is an option that works infallibly. 8)
What is the latest best freeware for making copies of my own DVDs?
By govtdog in forum DVD RippingReplies: 5Last Post: 22nd Jan 2012, 08:50 -
bad copies
By freewave in forum Newbie / General discussionsReplies: 7Last Post: 20th Jan 2009, 01:43 -
Copies Of DVD5's
By kpoman in forum DVD RippingReplies: 5Last Post: 22nd Oct 2008, 23:33 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 12:03 -
DVD copies
By JimboS in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2007, 22:33
