I made Queen of the Damned into 3 svcd mepgs but when I burned one it was fullscreen instead of the 16:9 I selected on TMPGE. I've tried both the 16:9 selection and the 16:9 525 line NTSC selection on TMPGE.
there are 3 different settings you need to worry about:
1) under the "video" tab, set your aspect ratio to 4:3 Display (this is for regular TV. if you have a widescreen HDTV, then you should set this to 16:9. keep in mind that this will only work on widescreen TVs, in case you want to watch it on a friend's regular TV) also, video format should be NTSC if you have NTSC tv and PAL if you have PAL tv
2) under "advanced" tab, source aspect ratio should be set to 16:9 525 line NTSC if dvd2avi said the source video was 16:9. i did queen of the damned awhile ago, and i believe the source was indeed 16:9. if you have NTSC, then it should be 525 line NTSC. otherwise, if you have PAL dvd, then it should be 625 line PAL.
3) under "advanced" tab, image positioning method should be set to "fit to frame (preserve aspect ratio)" or "full screen (preserve aspect ratio)" depending on which version of tmpgenc u have
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 05:15 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 16:46 -
How do I play/convert .MP4 files to play on my laptop
By tfoster in forum Newbie / General discussionsReplies: 1Last Post: 25th Jul 2008, 20:23 -
Does Toshiba HD-A2 play SVCD's?
By desertfox in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Aug 2007, 09:40 -
how to play seamless loop svcd's
By markwest in forum Authoring (VCD/SVCD)Replies: 8Last Post: 11th Aug 2007, 14:06
