Results 1 to 9 of 9
  1. Hi,
    I have used vcdhelp for a number of months to solve problems I have had with playing vcds and it is extremely helpful.
    However, now I want to start ripping dvds. If I don't have a dvd drive in my computer (I have cd and cdr drives), is there any way of doing it either by the use of a virtual drive or some software which recognises the files on the dvd even though the drives that I have installed at the moment cannot.
    Thanks,
    Jon
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    no
    Seaside, CA
    Internal DVD drives are relatively inexpensive. I suggest you replace the CD drive with a DVD drive. The Lite-On DVD drives are high quality and get good reviews. You can get a Lite-On 16x DVD drive for under $50 USD at newegg.
  4. Jon - no way to read a DVD without a DVD drive. You can play with VOBs from a DVD if someone with a DVD drive rips the disk for you. Only other option is to find a cheap drive. During the Holiday sales they are sometimes advertized cheap to bring you into the store.
    Panasonic DMR-ES45VS, keep those discs a burnin'
  5. Thanks for the replies.
  6. Just bought mine for $35.00. Artec DVD Drive with PowerDVD software.
  7. Originally Posted by katchupoy
    too expensive, bought my artec drive from staples maybe 2 months ago for $13.
  8. I capture from my DVD player just like my VCR and camcorder. No DVD drive needed. *waits for the laughter to stop*
  9. Originally Posted by fmctm1sw
    going through analog never as good as directly encoding from digital source (both video and sound suffers)
