  1. there is a couple of amine like blue seed 2 and angel cop where when i do rip it and squeeze it down using ifoedit it wont work.... it comes up with piece of the movie or just the begging credits..... is there something extra i suppose to rip or dont suppose to rip when it comes to movies with multiple episodes on it??????? or is this a ifoedit problem?????
  2. Load it into your chosen ripping program, and select the appropriate chapters. I have found that there are two format for anime dvd's they either have it all as one set in which case you will need to pick specific chapters, or they break them down into individual sets for each episode, which is kewl cause its easy lol, just rip the entire set for the episode you need.
    as for ifoEdit i have found similar problems with it, although i am new to it and possible im doing something wrong, i found another way for what i wanted to do and dont use it now.
    best of luck
    ciao
    TLTw
    The Hellsing family will purify this world...
