I've checked this site and others and from what I can tell my alba 114 should be able to play Intenso DVD+Recordable 4.70 GB discs, but when i insert a disc all i get on screen is:
CD-Rom
Playable files 0
total files 1
please insert a playable disc....
When I press 'Display' or 'Select' I get 'MP3' on the top lefthand side of the screen and various options but the display on the player says 'nodisc' and it won't play. I'm stumped.Is my player naff or are there options i should enable/disable to play the disc?
My player is connected to my Goodmans TV thru a scart cable - if this helps?!
Many thanks, Ckeeki
Results 1 to 1 of 1
Philips DVDR3576H/37 - Burned Discs Won't Play in Xbox, PC DVD Drive
By jbd5010 in forum Capturing and VCRReplies: 18Last Post: 20th Mar 2011, 04:11 -
Combined 2 discs into one, but disc won't play on dvd-player...
By StrobeLightEpileptic in forum Authoring (DVD)Replies: 5Last Post: 7th May 2009, 22:24 -
My player won't play burned discs anymore.
By uNderdog_101 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 30th Dec 2007, 17:44 -
DVD Logo licensing for DVD recordable discs?
By Wile_E in forum Newbie / General discussionsReplies: 11Last Post: 27th Oct 2007, 12:21 -
DVD Recorded discs won't play on Laptop!! ):
By SteveMKIIDub in forum Software PlayingReplies: 11Last Post: 21st May 2007, 18:24
