The DVD player I have does not read SVCDs (only VCDs). So I have been trying to convert an SVCD that I have to VCD. I initially tried the header trick, but the audio and video weren't synched. I'll admit I may have missed something doing that conversion, but I don't think so.
So, I decided to try and do the straight SVCD to VCD conversion using DVD2AVI and TMPGEnc. I am able to create the *.mpa, and *.v2d files using DVD2AVI, but that is where my problems begin. When I try to open the video file I get the following error message:
File "C:\Video Encode Temp\temp.d2v" can not open, or unsupported
When I go to the "TMPGEnc VFAPI Plugin" link from the "How to convert a SVCD or MPEG2/MP2 files to VCD, SVCD or DVD" page, that page tells me that version 2.59 (which is the one I have) has the VFAPI Plugin included. Also inside TMPGEnc under "Options -> Environmental Settings" there is a tab for VFAPI Plugin with a list of "Readers" and "Encoders" listed (and checked), so I think it IS installed, but it still won't read the *.d2v file.
If you have any ideas please let me know.
Thanks,
Britt
Ok, I have gotten TMPGEnc so that I don't get the error when I try to open an MPEG2 file, however now the program locks up when I try to open an MPEG2 file. Also, I still can't open the *.d2v file created by DVD2AVI.
Please HELP.
Britt -
Check that, I let TMPEGEnc sit long enought trying to open the MPEG2 file, and I still got the error, it just took a while.
I still need help.
Britt -
From what you are saying, the only problem I can see is unable to open the
D2V project, now check before you reply, do you have DVD2AVI.VFP in the
SAME location as your TMPGEnc ?Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 15:34 -
Different converting problems
By saiden22 in forum Video ConversionReplies: 3Last Post: 2nd Jan 2008, 12:29 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 14:17 -
Burning SVCD to a DVD (Not converting!)
By bebopdeluxe in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2007, 09:06
