I´ve tried 3 times now, and it always end up with this error- message:
Look Here...
Is there anything i can do about it?
Here is the DVD2SVCD log file:
WNASPI32.DLL 4.71.1.0
- 2002-12-14 23:23:12
- DVD to SVCD Conversion
- DVD2SVCD ver. 1.1.0 build 1b
Initializing
Initializing finished.
- 2002-12-14 23:23:17
- DVD2AVI
Creating DVD2AVI INI file:
- E:\Program\DVD2SVCD\DVD2AVI\DVD2AVI.INI
Variable settings:
iDCT_Algorithm: 32-bit SSE MMX
Executing DVD2AVI.
Executing DVD2AVI. Commandline:
"E:\Program\DVD2SVCD\DVD2AVI\DVD2AVI.exe" -CS=2 -YR=1 -EXIT -OF=[I:\SVCD\dire\DVD2AVI_Project_file] -IF=[I:\SVCD\dire\VTS_01_1.vob,I:\SVCD\dire\VTS_01_2.vo b,I:\SVCD\dire\VTS_01_3.vob,I:\SVCD\dire\VTS_01_4. vob]
Framerate: 25000
DVD2AVI processing done.
- 2002-12-14 23:25:39
- Free on drive I: 16908.55 mb
- AUDIO Extraction
Found PCM stream id: 0xA0
Filename: I:\SVCD\dire\Extracted_audio_1.wav
Audio1 delay: 0 ms
Audio extraction finished.
- 2002-12-14 23:29:20
- Free on drive I: 16031.19 mb
- AUDIO conversion
Encoding Audio. Filename: I:\SVCD\dire\Extracted_audio_1.wav
Executing BeSweet. Commandline:
"E:\Program\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "I:\SVCD\dire\Extracted_audio_1.wav" -output "I:\SVCD\dire\Encoded_audio_1.mp2" -logfile "I:\SVCD\dire\Encoded_audio_1.log" ) -ota( -g max ) -2lame( -e -b 224 -m s )
Audio conversion of I:\SVCD\dire\Extracted_audio_1.wav finished.
Audio conversion finished.
- 2002-12-14 23:33:28
- Free on drive I: 15903.24 mb
- Converting Pictures
Converting: E:\Documents and Settings\Johan\Mina dokument\Mina bilder\dire.jpg
Finished converting pictures
- 2002-12-14 23:33:43
- Free on drive I: 15902.62 mb
- Video Encoding using Cinema Craft
Executing Frameserver.
Closing program
Executing Cinema Craft Encoder.
StreamSectors: 833239988
AudioSectors: 136174780
VideoPAPO: 10797912
ScanOffsetBytes: 143744
SeqAligningBytes: 9135755
DVDBytes: 0
VideoEndHeader: 4
SubtitleSectors: 0
EmptySectors: 238.00
PictureSectors: 300.00
PureMPEGStream: 676987792.40
Seconds: 4798.48
CalcMPEGStream: 676987792.40
Frames: 119787
CDSize: 800.00
Number of CDs: 1
Cut point 795.00
Variable Settings:
Frames: 119787
Anti Noise Filter: 2
Passes: 4
Image Quality: 17
VAF file creation: On
Video Encoding Mode: Multipass VBR
Min. bitrate: 300
Max. bitrate: 2530
Avg. Bitrate: 1128
Aspect Ratio: 4:3 (No borders, encoded as 4:3)
---AVS Begin---
LoadPlugin("E:\Program\DVD2SVCD\MPEG2Dec\mpeg2dec. dll")
mpeg2source("I:\SVCD\dire\DVD2AV~1.D2V")
BicubicResize(480,576,0.0,0.6)
----AVS End----
AMD XP 2600+ Barton * ASUS A7N8X-X * 256 DDR pc3200 * Radeon 9000Pro 128mb * 280GB HD * WinXP Pro
Beater,
Your version of CCE requires a patch to be run to avoid getting this error message. I cannot point you directly to links from this forum but if you do a forum search for "CCE 2.50 SP CRC patch" or "CCE 2.50 patch" you should be able to find links to the zip file for D/load.....about 18k file only. Run this patch after unzipping and you will find your problem should disappear.
Regards
Studebarc
Found link for ya... http://www.bath.ac.uk/~susajb/Cinema_Craft_Encoder_2_50_SP_CRC_Patch.zip
how to encode?
By inject0r in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2012, 12:12 -
720p encode 700mb and 720p encode 1.5gb or over 3gb
By ali2k1 in forum Newbie / General discussionsReplies: 7Last Post: 26th Aug 2010, 13:09 -
Golf Swing & Mpeg & AVI video Streaming
By jamesh2 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Jul 2008, 07:19 -
I am in dire need for help *S-VHS Reporter Panasonic and Adobe Premiere Pro
By urdeluge in forum Video ConversionReplies: 2Last Post: 1st Mar 2008, 17:01 -
Re-encode to HD
By lotsill in forum Video ConversionReplies: 4Last Post: 23rd Sep 2007, 11:03
