I used DVDencrypter to rip the chapters from some dvds I have cause I want to make a compilation. I'm just starting to notice that dvd authoring software doesn't take vob files, they want mp2, mpg files, etc. What tool can I use to "convert" the vob file. Also I'm interested in converting the audio to mp3 or something similar to take up less space. Is there a way I can do this or do I have to start all over?
well you can create m2v files and ace files DVDencrypter. i am asumming you are ripping it using file mode if so just select your video and audio. just make sure you demux to a extra file for both.......
I ripped the dvd sections by chapter ifo mode. Can I work w/ the VOB file to get the m2v and audio files or am I screwed?
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 15:12 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
Breaking up DVD into downloadable files for website?
By Jinkies in forum Newbie / General discussionsReplies: 2Last Post: 19th Sep 2008, 08:50 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 17:15 -
Breaking down a VOB file into its component parts
By djdust in forum Newbie / General discussionsReplies: 3Last Post: 5th Sep 2007, 21:06
