How do I burn the cue bin to be able to use it on a RW disk? I getting tired of wasting R disks. I tried burning to an RW but it worked the same as an R and would not let me delete or add any more files to it. Seems to me the only way to do it would be to burn to the cue/bin to the hard drive and then copy the files to the RW disk. If this is it how do I do it?
Thank you
RW discs can be reformatted is all
you must select all the files to burn then put them on at one time in the VIDEO_TS and AUDIO_TS folders
if you are using the .bin/.cue combination then you must select to burn an image.
in this case the RW disc must be blanked and then written to one time
Can my dvd drive burn to dual layer disk?
By HartsVideo in forum DVD & Blu-ray WritersReplies: 7Last Post: 3rd Oct 2010, 16:07 -
How to burn DAO data disk
By logannsan in forum ComputerReplies: 4Last Post: 22nd Jun 2009, 13:17 -
How to burn music folders in a dvd disk?
By sumeshkri in forum AudioReplies: 20Last Post: 11th Mar 2008, 00:10 -
Burn in Disk Utility
By andredanton in forum MacReplies: 4Last Post: 12th Feb 2008, 13:41 -
Burn AVI file to DVD disk
By clms in forum Newbie / General discussionsReplies: 10Last Post: 20th Jul 2007, 15:10
