I'm currently using TMPGEnc version 2.59 (running on WIN XP Pro) and two times out of three when I try loading a video TMPGEnc gives me this error: Write error occured at adress 77F52109 of module 'ntdll.dll' with 00000000" Then when I close the program, I get the following error:
"runtime error 216 at 0003D948". I've tried using the previous two versions, but I still get the same message. Can anyone help?
Thanks.
[/img]
My problems was about 10 minutes in the encoding I got errors
or even hard crashes that rebooted my PC.
Try this:
Upgrade your BIOS to the latest firmware.
look at your motherboard manufactures website.
Still problems, format the HD and re-install windows from scratch.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 21:32 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
