I've download some DVDRip movie files from internet; however, I cannot hear any sound.
When I check the file extension, it shows .avi...
Can someone help me out with this problem???
Thank you![]()
Your computer may not have the necessary codec for the sound to work with the video. This depends on what sound is being used in the video. You have to check the properties of the video to find out.Originally Posted by PINOCCHIO
Just check on left for downloads or visit www.divx.com for the codec. -
You can also download GSpot (there is a link in Tools on the left).
Great program, tells what codecs you need to play the .avi and if you have both video and audio codec installed.
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 12:58 -
What are the downsides to having both onboard sound and Sound Card enabled?
By c627627 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 15:44 -
AVI - sound with VLC , no sound Toast burned
By BattyRoy in forum MacReplies: 15Last Post: 27th Jul 2007, 21:21 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
