Hey,
The usual dvds you buy in a store have an adverage bitrate of what generaly? I wanted to know because I know there is a bitrate limit (Like with SVCDs) where it gets too low, which is a good indication you need to split it onto 2 CDs. Is there a general rule of thumb for an adverage bitrate you shouldn't go bellow before your DVD becomes poor looking?
For that matter are most dvd movies which are under or at 4.7 gigs constant bitrate or Variable? What Constent value do they use if so? And if its variable, what a good length movie?
I know some movies fit under or at 4.7 gigs, however I need to add stuff to them and re-encoded them. It would be nice to know what settings to use so that they fit fine, and still have the same quality.
i don't know what the exact range of bitrates are, but i know they vary quite a bit depending on the movie...but if i recall correctly, they say you shouldn't go below 3000-4000 i think
store discs, that is factory ones, now use vbr's
i use a 4000 standard, action gets messed up under
that...go with what u know -
My expierence with BitrateViewer indicates "most" movies are at 6000 average and 9800 maximum and always VBR.
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Converting Dvds, Settings with bitrate
By Ekeus in forum Video ConversionReplies: 24Last Post: 22nd Mar 2010, 18:19 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 20:43 -
What's the Best Bitrate for Converting DVDs to .264 MP4 files for xbox 360?
By keyed in forum Video ConversionReplies: 1Last Post: 3rd Feb 2008, 02:04
