I'm new to DVD recording and looking for some very basic information. I have a SONY VAIO with a Pioneer DVR-104 DVD-RW. My question is this...I just bought some DVD+R discs, can I use them? or should I return them and get something else? If so what is the best type of media for me to use?
Thanks for any advice
Glenn
you cannot use DVD+R in the 104, as it is only a DVD-R/W capable drive...so for the write once, you can only use DVD-R (minus R)...which can actually turn out better sometimes, as the -R is usually cheaperOriginally Posted by glenn29
Pioneer has only supported drives DVD-R and DVD-RW
DVD+r and DVD+RW are different format and won't be able to burn them on your burner.
Return DVDs and get yourself -R and -RW=[ vinchi007 ]= -
Thanks a lot for the information. Sorry to have such a dumb question but ya gotta start somewhere.
not a dumb question...smart of you to ask firstOriginally Posted by glenn29
and yup, we all gotta start somewhere, i'm still in the process of learning so much
You can try to use the Ritek or optodisc dvd-r, those are very good dvd-r media and price, just visit www.supermediastore.comOriginally Posted by glenn29
just mention refferer "mcopier" at the comment
Good Luck
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 12:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 16:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43
