I´ve converted several videos from my DV camera to PAL format on the computer and then put them on DVD+R. The only thing is that some them of them appear jumpy and appear to skip. Is there anyway to minimize this? I know that the PAL format is only at 25 fps so it has to drop some frames. I was wondering if field order had anything to do with this also. The videos are from a DV camera, but all have been edited and saved as AVI´s. In thise case, should I still have field B first?
Thanks,
Andrew
Results 1 to 1 of 1
do I have a field order problem ?
By davexnet in forum Video ConversionReplies: 9Last Post: 13th Dec 2010, 14:41 -
Field Order Question
By daz1976 in forum DVD RippingReplies: 2Last Post: 11th Feb 2010, 10:27 -
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 01:38 -
Reconciling different Field Order
By vegasarian in forum EditingReplies: 8Last Post: 14th Mar 2009, 12:43 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 17:14
