Hi all,
Is there a program out there that can tell you what the delay should be in an audio track. The reason I ask is because I have been trying to put Triple X SVCD onto a DVD. I've used the guide that on this site, but it doesn't say about audio being out of sync. Is it maybe because I've joined 2 svcd's together to make one big mpeg and then converted to DVD from there?
Please help it's really annoying
Regards
Jimmy
I'm newbie in this as well, but from I read - You did OK. Merging files is the first step. What did you encoded your audio with,codec? Or is it AC3?
Check the tutorial on doom9.org
It's pretty organized and easy to find, also it's understandable.
Hope this helps ya.=[ vinchi007 ]=
(avstodvd) Converting m2ts to dvd...sudden sync probs.
By newbtube in forum Video ConversionReplies: 17Last Post: 2nd Apr 2011, 23:27 -
Audio sync probs
By just_kim_usa in forum Video ConversionReplies: 2Last Post: 27th Jan 2011, 14:23 -
DVD FLICK audio sync probs
By dalek7 in forum Authoring (DVD)Replies: 2Last Post: 19th Aug 2010, 02:14 -
video and audio sync probs
By reynardthefox in forum Newbie / General discussionsReplies: 3Last Post: 3rd Mar 2010, 00:23 -
In VirtualDubMod, if the audio is longer to video would it cause sync probs
By breadbin in forum Newbie / General discussionsReplies: 2Last Post: 14th Jul 2009, 06:35
