Anyone have this? does it actually work? it said that it use vcd 1.0, 1.1 and 2.0. i was just wondering if it could play svcd because i rip most of my dvd in svcd? also i found this for $40 anyone know where it's cheaper? thanks
I have one. It played all my vcds fairly well until it finally killed my laser after about 3 months. What they don't tell you is that the PSX was never meant to constantly read from a disk for 2 hours at a time. You'll notice that when you play games it will stop sometimes for 5 mins or so, and it will only actually spin during certain parts.
This definitely will not play SVCDs. If you spend another $20 you could get a cheap dvd player that would play VCDs and SVCDs and it would last alot longer than your psx laser would. -
I have had one for 1 year.
I use it at least twice a week just for VCD's.
My laser hasnt burnt out.
You must have constantly played it right after watching the movie.
If you read the instruction booklet(which you probably didn't) They say to wait for 30 min after watching the movie. This helps cool the laser down, and not destroy it. You can also always buy a new laser from www.liksang.com
They are pretty cheap.
I have a PSone with a modchip, VCD card, LCD Screen, ANd a battery pack that lasts 4.5 hrs.
I have not had any trouble with it.
Qshartle"Good Luck 007"
In Memory of Desmond Llewelyn -
I have video carde for the psx too. I personaly think that it suck. I will kill your lense. And who have time to wait for 30 min for another movie. You can get a DVD for less then $100 these day and I'm not talking about apex dvd(they drop vcd).
The suck thing about the psx video card.
Can't zoom.
2x forward/rewind
No SVCD
It will kill your lense.There is always one who is always greater. Never give up.
dvd movie on sd card
By cldarko in forum Portable VideoReplies: 6Last Post: 24th Dec 2010, 23:48 -
Getting a movie on 2 x 256mb SD card
By NeWcS in forum Video ConversionReplies: 1Last Post: 8th May 2008, 00:48 -
Non Profit With Old Pinnacle Card Needs to Make a Movie
By MiracleMovieMaker in forum Capturing and VCRReplies: 12Last Post: 25th Feb 2008, 06:13 -
movie on memory card
By BroomQueen in forum Video ConversionReplies: 2Last Post: 17th Oct 2007, 12:47 -
Burning small movie clips from camera(SD card) to dvd
By wesburnsco86 in forum Authoring (DVD)Replies: 6Last Post: 22nd Jul 2007, 16:09
