I have burned a mpeg2 to a svcd and now would like to take the mpeg2 back off the cd to reburn on another cd (changing from pal to ntsc).
I have tried just copying it but no player will play it.
I have windvd and other mpeg2 codecs so I know the file is not in the correct format and needs to be converted back to a regular mpeg2.(I have tried vcdgear gui with no luck )
Any of you guys know the solution?
kwirkie
There's something wrong with your media. It should work FINE (as long as the original SVCD was working!).
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 14:18 -
converting to mpeg2
By thecrock in forum Newbie / General discussionsReplies: 11Last Post: 12th Nov 2007, 16:08 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 14:17 -
Burning SVCD to a DVD (Not converting!)
By bebopdeluxe in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2007, 09:06 -
SVCD / MPEG2 - bad packet stops file.
By Steve Walsh in forum Authoring (VCD/SVCD)Replies: 5Last Post: 9th Jul 2007, 12:03
