one more try
[img]test.gif[/img]
Results 31 to 47 of 47
ok I think I may have it this time
then I am going to make a guide with pictures
[img]test.png[/img] -
Jarvis,
Do you think you could elaborate a little more on your 20 step guide on DVD9 to DVD5 keeping the menus. I am new to this. I think I understand the basic process, but not all the details yet. If you don't have time to do this do you know of a link to such a site that might provide me with steps and screen shots? Thanks. -
well,
I do have a bunch of screen shots of how to do it.
but for some reason i can't get the infernal things to load on here
if you know how I can do that then I will be able to post them -
jarvis1781 you can edit your posts.
also DoItFast4U seems to be doing the same thing here. http://dvdguides.trilight.net/ -
Can you also send me the *.ini file about DVD2SVCD ? Thank you very much.
My email address is gundammas2000@yahoo.com.tw.
Thank you. -
VERY COOL!!!!!!!!!
Now if anyone has a question about a step I can show them what to do
Glad you finally got the image to load!
Screenshot for me:
Powerbit stuff and most important--where do I change these (powerbit) settings in dvd2svcd?!?
Stiil confused on step 15
where can I find dvdimager? -
I do , I never used ifoupdate, so first: Do I need to rename only the vobs?
And Second what .ifo do i need to use???[-Neoh*-]|[-Cheers-] -
Jarvis,
Could you please email me your guide with the screenshots please? My email is mpresto@hotmail.com. I would really appreciate it. Thanks. -
I think I've got everything but the 2nd from last step. Here's what I've got (backed up so I can play with them/the final step):
1) Original VIDEO_TS from DVD rip
2) Authored VIDEO_TS (& AUDIO_TS) from DVD Maestro
Ok I know I want to delete the original VOBs and replace them with the authored ones. I don't want to delete the original VTS_XX_0.vob file because that's the menu.
Question: What about the VIDEO_TS.BUP/VIDEO_TS.IFO/VIDEO_TS.VOB files? Do I want to delete them and replace them with the authored VIDEO_TS files, or keep the originals? -
Vejita
you are on the right track
but you don't do anything with any of the other files
you just use ifoupdate to correct the information in the main movie .ifo -
jarvis could you tell me how to do this without the menu cause sometimes the menu does'nt matter to me my email address is2quik@dr.com. thanks
ummm....2quik if you dont want the menu there are easier ways to do that
just rip the streams and author with spruce or ifoedit
then burn
DVD9 split to two DVD5's while retaining menus and video quality
By ashes2flames in forum DVD RippingReplies: 6Last Post: 28th Feb 2011, 09:10 -
Rebuilding a DVD9 to DVD5 keeping DTS intact
By zoomie in forum Newbie / General discussionsReplies: 13Last Post: 6th Jan 2011, 01:37 -
How do i convert an (ISO) dvd9 to a dvd5 and keep the menus???
By jcurrieirocz in forum Video ConversionReplies: 5Last Post: 26th May 2009, 09:15 -
Is there EZ way to convert DVD9 to Half-D1 DVD5 and keep all menus, etc.
By nwl in forum DVD RippingReplies: 3Last Post: 27th Jul 2008, 02:22 -
Quick and easy DVD9 to DVD5 video backup under Linux
By danboid in forum LinuxReplies: 7Last Post: 30th Sep 2007, 12:05
