  1. I have every episode of Band of brothers ripped into each seperate image file(SVCD)
    How can I put couple of them on one DVD-R and create a menu that I could chose chich one I want when I play it on my stand alone dvd player.
    Please tell me some tutorials and some apps.
    Thanx
    =[ vinchi007 ]=
  2. thanx for the tutorial. It still doesn't answer my issue - since I don't know how to create menus. I want to be able to create a custom great looking menu. I'll do the graphics and want to chose the background audio. Is there a program that can do that?
    =[ vinchi007 ]=
  3. I have been using ULEAD DVD workshop which like alot of other Authoring tools will allow menus "with Back ground audio etc",
    You should be able to make a index based menu system with this software.But be warned it doesnt come cheap.I am sure other members will be able to steer you to similar products..
  4. I don't honestly care, since I can persuade my company to pay for it
    I don't care about the price. I just want to learn how to do this stuff.
    Thanx for the advice.
    PS I think its price is $999
    =[ vinchi007 ]=
    Nov 2002
    Chicago, IL
    You can save some dollars and buy Ulead's DVD Movie Factory. Should work great for what you are trying to do. It doesn't have many features but it does what it does and does it well. You can download a trial verson from their web site or download the full version. Or, you can buy it in a store.
    Works for me..... best of luck
