trying to creat mpg for vcd
i dont know what im doing wrong but, i convert avi to mpg in the following way
i decompress then vd
in virutal dub i select the follwing options
full processing, no compression, select 44100, then sav wav
then in tmpgenc,
i load pcm video (the file thats decompressed)
and load the wav, i select source range, 0 to about half way into avi
then click noise reduction (helps a little)
then in other settings
audio:- errorcorrection
advanced:- ghost reduction and sharpen edge and full screen keep aspect ratio (dont matter what its in box mode or widescreen)
video:- motion search to highest/slowest
and then sitt back for about 4-6 hours for encoding
now the prob, the quality is ace on me comp but when i burn using nero v 5.5.9.17 and try to play on me dvd player , which does play every type available (excpet avi) it freezes, loses sounds and get those horrid green squares and sometimes half the screen goes mental
am i missing anything
Please help , as im getting fed up now, me m8's vcd work fine on my dvd player and he uses the excact routine as above
also, im trying the method of fitting 1 hour 30 min movie onto 1 cd, i can get the mpg file down to around 680 megs, by changing the bitrate down from 1150 to around 900 odd, but again when trying to burn using nero it says "this is not the proper format, nero will convert", and it does back upto 1 gig file, it must be converting back to 1150 , so wont fit, im trying to look for the bit that says "non standard vcd" but i cant find it in nero
any help please -
SORTED, what an idiot i forgot to select correct template at step 1, silly idiot, aslo i have now worked out how to get 1 film on ONE vcd, just encoded Swordfish, PERFECT quality (ok not quite dvd but as good as), no lip sync probs, no glitchy bits, colour jobs etc, well chuffed and happy
whoever wrote the bitrate calculator need a medal, very clever person
Laptop HP: No more display
By themaster1 in forum ComputerReplies: 20Last Post: 4th Jan 2011, 20:59 -
Playing Video on display 2 and display 1 goes black
By sidewaysdriver in forum Software PlayingReplies: 2Last Post: 3rd Aug 2010, 01:36 -
BSOD while trying to display
By src2206 in forum Software PlayingReplies: 7Last Post: 11th Jun 2009, 14:27 -
slightly off topic - added router - 2 machines dodgey upload rates
By BattyRoy in forum MacReplies: 5Last Post: 12th Jan 2008, 00:40 -
Display Drivers
By shawmd in forum Newbie / General discussionsReplies: 10Last Post: 3rd Jul 2007, 17:30
