Hi all,
I have a pal divx here and want to use cce to convert it to a svcd but was wondering wether i will need to use smart deinterlace as its a pal divx (which was encoded with deinterlace when ripped from the dvd vobs), just curious as i want the best quality possible, many thanx
tigro
DivX is not interlaced whatever settings were used in its creation.
ru sure? because when i encode dvd 2 divx i get an option to use smart deinterlace, fast deinterlace, and inverse telecine... which i use smart deinterlace. any ideas?
DVDs are sometimes interlaced, DivX never is. So, when creating a DivX from an interlaced source, you have to de-interlace. SVCD can be interlaced, but since your source is not interlaced, then you have no interlace/de-interlace options to think about.
Your source is progressive, and there is no point in attempting to interlace your target SVCD, because it is not relevant. -
i didnt mention if the ripper, (who ever ripped it), used smart deinterlace but i thought all PAL movies needed 'smart deinterlace' to be used for some reason which is why i was wondering wether i need to use smart deinterlace when turning it into a svcd?
Almost all PAL DVDs are progressive, as are all DivX. I've come across about half a dozen interlaced PAL DVDs - almost all derived from TV shows. You can select any de-interlace option you want. It shouldn't do any harm, but it certainly won't do any good - unless you actually have a rare PAL interlaced DVD!
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
DivX 7 Pro mp4 to Divx conversion
By mkochsch in forum Newbie / General discussionsReplies: 1Last Post: 14th Mar 2010, 02:22 -
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 06:25 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 16:46 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
