I´m trying to convert a DivX avi into VCD. So far, I tried about 10 Movies with only one succesfull conversion. The other ones where either out of sync or didn´t encode all the way. I know that there are lots of different DivX files (Xvid, 3vix, DivX5 etc...). I´m using ffmpegXg to convert the files. Now my qustion: Do I have to convert the avis first to mov (using Divx Validator or Divx Doctor 2, or DivosX tool, or avi2mov) in order to convert them with ffmpegX? Should I leave thm unchanged (avi)? Which avi to mov conversion tool should I use? Is there a "foolproof" way to convert them?
thanx
yes, better to have them in a .mov container, and you can use Divx Doctor II from 3ivx.com for that.
Why not try to encode your DivX files to vcd with TMPGEnc?
It is much easier,then you can burn it with Nero or other burningsoftwares.
Convert A DivX with AC3 To VCD
By Stinky in forum User guidesReplies: 43Last Post: 23rd Jul 2011, 03:55 -
VCD to Divx conversion
By silverarrow in forum MacReplies: 14Last Post: 18th Feb 2010, 08:25 -
Divx to VCD
By d_unbeliever in forum Authoring (VCD/SVCD)Replies: 16Last Post: 30th Apr 2009, 00:19 -
VCD to DIVX Conversion
By DarkPhoenix77 in forum MacReplies: 2Last Post: 16th Mar 2009, 12:28 -
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 17:01
