I have ripped my movie with smart ripper and used dvd2avi to produce a d2v file. This is my first time using tmpgenc. I am using tmpgenc plus full version 2.59.47.155 without mpeg2 restrictions. when i try to select the d2v file as the video source the file type is not in the pull down box. when i swith to all files and try to import that way , i get file type not recognised.
Can anyone help?
Not sure i follow u m8. are u saying d2v is the same as m2v for tmpg. why do the guides say use dvd2avi then? I assumed it was using the d2v file in the sme way as cce.
No.
Have you tried just easy renaming that file so tmpgenc can recognise it???
If this doesnt work tmpgenc maybe needs a codec which isnt installed or cannot find this codec... -
Have you ran TMPGEncVFP_install.bat yet?
It will be in TMPGEnc dir.May the force be with you.
no audio on playback tmpg
By devdev in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2011, 12:05 -
jerky tmpg
By devdev in forum Authoring (DVD)Replies: 6Last Post: 12th Aug 2010, 08:14 -
TMPG DVD Author-old version
By Mållgan in forum Authoring (DVD)Replies: 12Last Post: 7th Mar 2010, 16:46 -
tmpg dvd author 1.6 help plz
By nwa in forum Authoring (DVD)Replies: 8Last Post: 6th Jul 2007, 18:59 -
TMPG plus vs. free version
By bellyting in forum Newbie / General discussionsReplies: 2Last Post: 4th Jul 2007, 01:11
