  1. Ok I am using smartripper to rip the dvds and that works fine but and when I use Flask to convert it to divx and finish. They always have the same problems with the sound bieng 3-5 seconds out of sync with the movie. If anyone can help that would be great.I also heard that it is possible to use virtualdub to fix the problem but don`t know how. Any help will be appreciated.
    Sometimes you do.......and sometimes you run and run so the axe welding sicko does`nt cleave open your chest.
    Dec 2002
    Belgium
    I had the same problem i solved it by using another program.
    Now I use dvdX it works fine and you can encode it also with this program from you hd. But if you want subtittles you must rip the ifo file also.
