i have 24fps mpeg(which is encoded form xing), but it doesnt look good, something disturbs the eyes,and some fast scenes cant be understandable.. is there a way for correcting this problem?
thanks guy![]()
Hi,
There's no easy way to correct your file created with the Xing encoder. The best way to get better quality is to re-encode using TMPGenc and set the "Motions search precision" to High Quality (Slow).
Greetz,
pSyChO dAd
The difference between genius and insanity is only measured by success ! -
That's a good suggestion, but TMPGEnc likely won't be able to improve on video that already has a problem (garbage in-garbage out). What is it that doesn't look good? Can you be more specific than "something disturbs the eyes"?
You must be encoding in PAL, I encode in NTSC at 29.97 and even when I encode at 2520 in XVCD I still get a little strange motion blur, I since have moved over to SVCD and that seems to have solved the problem, plus I get a sharper picture with colors that look brighter.
I use TMPGE beta b version to encode with. -
the movie is from dragon forever(jackie chan)
especially at figthing scenes the punches and kickes cannot be seen easily something like slow motion proccess but sequence time is correct.time ok but motion has lack of frame i think..
buffering stream for smoother playback
By pensioner in forum Video Streaming DownloadingReplies: 1Last Post: 26th Sep 2011, 08:25 -
Ulead DVD MovieFactory 6 prob w/using 3.7GB mpg to make DVD
By GSP_87 in forum Authoring (DVD)Replies: 4Last Post: 6th Nov 2009, 05:05 -
Tips On Optimizing VLC for Smoother Playback in OS X???
By Danteism in forum MacReplies: 9Last Post: 24th Jan 2009, 04:27 -
(Smoother) Cropping / Blending with Audacity
By Seeker47 in forum AudioReplies: 2Last Post: 3rd May 2008, 18:05 -
Easy Freeware to make DVDs out of mpg and avi files?
By gail22 in forum Authoring (DVD)Replies: 13Last Post: 15th Oct 2007, 19:31
