Ripped the vob's just fine. Used dvd2avi forced film. Encoded to ntsc film with 3:2 pulldown on playback. After burning the disk the audio was out of sync. Not by much but you could tell that the audio was ahead of the video. Now when I use dvd2avi and don't force film and leave it at 29.97 then encode to ntsc 29.97. Everything is perfect when playing back on dvd player. I would like to use 23.976 because the video looks better and also takes less time to encode. What can I do to solve my problem. Thanks for any help.
If you are using TMPGEnc to encode, you can use Source Range to adjust the audio gap.
Hello. -
1) try a different version of dvd2avi (i've experienced some problems i discovered could be removed by using the latest dvd2avi)
2) if dvd2avi can't solve it, you can try using flaskmpeg/avisynth to frameserve into tmpgenc, instead of dvd2avi (this worked on the 2nd DVD of LOTR extended edition when neither version of dvd2avi i had would get rid of the gradual audio syncing problem)
http://www.vcdhelp.com/dvdtovcdflask.htm
btw, keep in mind, using the audio skew feature like Tommyknocker mentioned only works if the audio is outta sync by the same amount throughout the movie, if it gradually gets outta sync, then you can't use this method.
23.976 to 29.97 weird FPS problem
By michcio in forum SubtitleReplies: 10Last Post: 11th Jan 2011, 05:58 -
Problem with subtitles in videos of 23.976 fps
By sgbd in forum Authoring (DVD)Replies: 5Last Post: 7th Nov 2010, 19:56 -
NEW PROBLEM: Will Not Encode
By totalnewbiedumbass in forum ffmpegX general discussionReplies: 4Last Post: 14th Dec 2007, 11:25 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 12:34 -
Difference?? 23,976 pics/s or 29,976 fps
By twanbaten in forum Authoring (DVD)Replies: 1Last Post: 6th Nov 2007, 12:29
