I wanted to encode my film to a vcd format(mpeg) but i dont know the video source. if it is ntsc, ntsc film or pal. how would I knoe?
I don't think the source video type really matters. So don't worry about it.
Originally Posted by legionpc
Huntress, if your source file is avi format, open it in virtualdub and go to file->file information. It will tell you the resolution, framerate etc. Check this info against the NTSC/PAL info listed at www.vcdhelp.com/vcd
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 14:46 -
ENC encoding versus no ENC encoding
By RL in forum ffmpegX general discussionReplies: 3Last Post: 4th Feb 2011, 17:44 -
AVCHD encoding format vs. H.264 encoding format?
By coody in forum Authoring (Blu-ray)Replies: 3Last Post: 28th Aug 2010, 20:51 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 14:11 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 00:31
